Technical Data
| Non-Turbo | Twin-Turbo | |
| Engine | 2JZ-GE | 2JZ-GTE |
| Type/Cylinders | Inline/6 | |
| Valves | 24 | |
| Injectors | 330ccm | 550ccm (Japan 440ccm) |
| Displacement | 2997ccm | |
| Compression Ratio | 10:1 | 8.5:1 |
| Bore*Stroke | 86.0mm*86.0mm | |
| Power kw/hp (DIN) Power kw/hp (SAE) |
168/225 @ 6000 rpm 164/220 @ 5800 rpm |
243/330 @ 5600 rpm 239/320 @ 6000 rpm |
| Torque | 290NM @ 4800 rpm | 440NM @ 4800 rpm (VVt-i 451NM @ 3600 U/min) |
| Acceleration 0-100kph | 6.8sec (Automatic 7.7) | 5.1sec (Automatic 5.8) |
| Top speed | 240kph | 250kph (limited, Japan 180kph) |
| Length*Height*Width | 4515mm*1275mm*1810mm | |
| Wheelbase | 2550mm | |
| Brakes front/rear dia | small type: 2 Piston 296mm/1 Piston 307mm large type: 4 Piston 323mm/2 Piston 324mm |
