Turbocharger Specification
| J-Spec | Export-Spec (US/EU) | |
| Maker | Toyota | |
| Type | CT12B | CT12B |
| Turbine Size Inlet/Outlet | 60/48mm | 52/44mm |
| Turbine Material | Ceramic | Steel |
| Compressor Size Inlet/Outlet | 62/39mm | 58/39mm |
| Compressor Material | Aluminum | |
| Maker | Toyota | |
There are certain differences between the 2JZ-GTE engines destined for the Japanese Domestic Market and the North-American and European Market. J-Spec Export-Spec Impact Engine Peripherals…
In Europe Japanese car manufacturers have a hard time competing against domestic makers in the segment of high-priced cars. Domestic competitors are well-established, customers spoiled…
JZA80 Group (by GERMAN SUPRA MKIV GROUP – www.jza80.eu) is proud to present a world’s first: A full compilation of all Toyota-genuine Supra MKIV accessories…
VIN-Plate / VIN-Sticker Explanations for the lines. 1. MODEL Internal Equipment code 2. ENGINE Engine (2JZ-GE or 2JZ-GTE) and displacement (2997ccm) 3.…
