Comeback der Supra
- Calgar
Re: RE: Re: Comeback der Supra
Macht Sinn, da BMW wohl sogar die Logos für Toyota einkauft in dem ProjektJapanfanatic hat geschrieben:Soweit ich das übrigens erkennen kann, wurde das Foto bei BMW in der Hufelandstraße gemacht, gegenüber vom FIZ
Comeback der Supra
Quelle: http://www.bmwblog.com/2016/06/16/bmw-z ... -detailed/The BMW Z4 will be wear a chassis designation of G29, to go with the rest of the new ‘G’ named BMWs and the Toyota Supra will wear a J29 chassis code.
Yes
Auch mal zum Nachdenken:
http://www.carmagazine.co.uk/spy-shots/ ... d-details/
Wäre witzig wenn am Ende etwas ganz anderes rauskommt.
Comeback der Supra
http://www.carscoops.com/2017/04/bmw-sa ... s-are.htmlThe vice-president of sales and marketing for BMW’s M division says that both manual and dual clutch transmissions will die out.
The imminent death of the manual transmission has been coming for years and shouldn’t surprise anyone, however Peter Quintus’ belief that DCTs are also on the way out might shock a few people.
While speaking to Drive, Quintus said that the advantage of quicker shifts dual-clutch transmissions once had over traditional automatic gearboxes are dwindling.
“It's more a question of how long has the DCT got to go. How long will it last? We are now seeing automatic transmissions with nine and even 10 speeds, so there's a lot of technology in modern automatics.”
“The DCT once had two advantages: it was light and its shift speeds were higher. Now, a lot of that shift-time advantage has disappeared as automatics get better and smarter,” Quintus said.
The executive also revealed he isn’t sure if the next-generation M3 or M4 will have the option of a manual transmission.
