V160 gearbox
dayle.legrange
V160 gearbox
Beitrag von dayle.legrange »
Hello all. I need serious help, my gearbox is being worked on by a mechanic who specializes in gearboxes, he's in his 70s and is having a hard time removing this gear off. He's broke one of the teeth, it wont slide off the rod, I myself have even tried...does anyone know what to do? Unfortunately he's applied heat to it aswell but that didn't help...
Also he isn't sure what gear this is, can someone tell me? 2nd cluster is all he said
The reason for the gearbox tear down is cause of a strange loud rattling noise whenever the engine (while in any gear) is reved, the 1st initial power from the flywheel to the clutch for a split second only...but while driving in any gear the noise goes away.
Below is a video link of the noise (all 4 wheels are off the ground and in first gear)
https://youtu.be/Hc1vPhhE00o
Danksagung erhalten: 58 Mal
Re: V160 gearbox
Hi, do you guys have the V160 Workshop manual? If not, send me your eMail adress via PN I can send it over to you
dayle.legrange (01.02.2021, 23:43)
