Hi guys,
I'm fitting a HKS SLD T6 at the moment and having some trouble with the wiring.
Anyone have some pictures of the ETCS and TRC wiring with the HKS SLD T6 connected? Or a picture of the ETCS and TRC plugs.
Thanks!
Fitting HKS SLD T6
Casper
Re: Fitting HKS SLD T6
Hi Jack, thank you. That's the exact file I'm using to install the SLD. However I'm a noob when it comes to wiring and can't find the correct connectors (trc and etcs). Do you have a picture of those?
Thank you.
Casper
Thank you.
Casper
I think thats not all could that be? Because the sld t6 has 16 wires how i remember and the other 4 comes to the conectors from the engine ecu?JackEnox hat geschrieben:https://jza80.de/phpBB/viewtopic.php?f=7&t=825&hilit=SLD
I have no picture but the conector you are searching for is from the TRC Ecu.Casper hat geschrieben:Hi Jack, thank you. That's the exact file I'm using to install the SLD. However I'm a noob when it comes to wiring and can't find the correct connectors (trc and etcs). Do you have a picture of those?
Thank you.
Casper
In a RHD Supra that sits passenger side behind the carpet. Left from the engine ecu is another smal ecu thats the TRC one with the connector you are searching for. I dont know how it is on an LHD Supra but its also passenger side but it could be that its mirror reversed (right side from the engine ecu) I hope that helps
